Hola a todos, más menos lo tengo claro, mi duda es si es preciso desmontar el paragolpes y si es muy complicado. Por otro lado no acabo de ver cómo va conectado el cable amarillo, que es esa caja en la que va, y para finalizar, el fusible que va con cable conector debe ser de 10A? Gracias, saludos.
Hola, no es complicado si lo haces con cuidado.
Aqui te dejo los pasos que tienes que seguir.
1. REMOVE RADIATOR COVER
(a) Remove the 2 hood bumper cushions. | |
(b) Remove the 4 clips.
(c) Disengage the guides to remove the radiator cover as shown in the illustration.
| Remove in this Direction |
2. SEPARATE FRONT FENDER MOULDING SUB-ASSEMBLY LH
(a) Apply protective tape around the front fender moulding sub-assembly LH.
(b) Remove the 3 screws.
(c) Remove the 2 clips.
(d) Using a screwdriver, turn the pin 90 degrees and remove the pin hold clip.
HINT:
Use the same procedure for the RH side and LH side. | |
(e) Pull back the edge of the front fender liner LH and disengage the claws by pushing the area indicated by the arrow in the illustration with a finger.
| Place Hand Here |
NOTICE:
- Do not apply excessive force when pulling back the front fender liner LH.
- To avoid damaging the claws, do not forcibly pull the front fender moulding sub-assembly LH.
(f) Disengage the clips and separate the front fender moulding sub-assembly LH.
3. SEPARATE FRONT FENDER MOULDING SUB-ASSEMBLY RH
HINT:
Use the same procedure as for the LH side.
4. REMOVE FRONT BUMPER ASSEMBLY
(a) Apply protective tape around the front bumper assembly.
HINT:
